May 13, 2020, 16:47 |
False diffusion in Lid driven cavity
Mudit Mehta
Rep Power: 6 |
Please Help!!! Hello, Can someone please explain how a false diffusion will look like in Lid driven cavity problem. (Reynolds number = 100)
I am using first order upwind scheme for the discretization of convective terms in steady state navier stokes equation and using SIMPLE method. |
May 13, 2020, 17:32 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
You are working on a test-case that has no analytical solution. we already discussed such issue. The numerical diffusion can act as if you are solving the lid-driven cavity at a smaller Re. But that is locally determined by the cfl value. For the steady case you need to consider the grid size. However, your question is not well stated. |
May 13, 2020, 17:38 |
Mudit Mehta
Rep Power: 6 |
The grid size i have taken is 65x65 and 21x21. I have generated u, v, p countours, streamlines, u velocity along vertical geometric centre of cavity and v velocity along horizontal centre of cavity. Can we look at false diffusion from here?
I have values to compare from ghia et. al. of u velocity along vertical line and v velocity along horizontal line. |
May 13, 2020, 17:41 |
#4 | |
Rep Power: 71 |
You can only perform a grid refinement study and report the velocity profiles at each grid. |
May 13, 2020, 17:42 |
Mudit Mehta
Rep Power: 6 |
Okay. Thank you so much
false diffusion, lid driven cavity, python script, simple algorithm |
Lid driven Cavity | suman91 | SU2 | 3 | May 24, 2022 05:23 |
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores | puneet336 | OpenFOAM Running, Solving & CFD | 11 | April 7, 2019 00:58 |
Boundary Conditions at Corners, lid driven cavity | t.teschner | Main CFD Forum | 8 | August 17, 2016 08:20 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
is there any parallel code for the famous Lid Driven Cavity flow? | gholamghar | Main CFD Forum | 0 | August 1, 2010 01:55 |
