Thrust, Moment and Power Coefficient
Old   May 21, 2020, 10:17
Default Thrust, Moment and Power Coefficient
MA
mazhar16823 is on a distinguished road
I have taken three-bladed HAWT; But in the simulation, I am modelling the flow around one wind turbine blade by applying periodic boundary conditions using STARCCM+.
I created a report for the moment coefficient, that shows the data for Cm was stored at each time-step until the end of simulation. After which I ran the report to calculate the Cm. Now, I want to calculate the Cp, for which I use the formula Cp=Cm*TSR is that a correct way or I shouldalso multiply it with 3 considering three-bladed HAWT? If I do so, the Cp is unacceptable, however if I just use Cm*TSR it gives the Cp in a good range.
Secondly, I didn't create the report for thrust coefficient during the simulation. Is it possible to calculate it post-simulation and how?
Thanks for your time. Your answers wil be highly appreciated.
mazhar16823 is offline   Reply With Quote
power coefficient, starccm+, thrust coefficient
How do I calculate power coefficient with respect to TSR of savonius VAWT ? ahmedna8 FLUENT 2 October 4, 2022 18:17
Power coefficient from Moment Coefficient mazhar16823 Main CFD Forum 0 May 20, 2020 13:02
Calculating Performance Coefficient (Cp) in Fluent aptahaney FLUENT 1 September 5, 2015 19:22
is it necessary to multiply by number of blades with moment to calculate the power? er_ijaz FLUENT 2 November 16, 2013 19:04
Calculating pitching moment for power input Zonexo Main CFD Forum 0 June 12, 2008 06:07
