Suddhoo-Hall Multielement Airfoil Validation Case
Old   May 31, 2020, 12:03
Default Suddhoo-Hall Multielement Airfoil Validation Case
Ungarn (HUN)
lobius is on a distinguished road
For a Course I am required to analyse the Suddhoo-Hall Airfoil which is a common validation case as the exact potential solution can be calculated. The problem is listed in this very site as a 2D validation cases as well: https://www.cfd-online.com/Wiki/Suddhoo-Hall_airfoil
However I cannot find any resources on which I can base my geometry and compare the result other than pictures. Does anyone has geometry for this multi element airfoil, or any suggestion from where could I retrieve it? (Maybe the original paper?)
With much thanks!
lobius is offline   Reply With Quote
Old   June 19, 2022, 22:13
Banned
milkblink is on a distinguished road
With much thanks!
dordle
Other than photographs, I am at a loss when it comes to finding information on which to base my geometry and compare the results. I'm looking for geometry for this multi-element airfoil, but I'm not sure where to look. (Perhaps the original piece of work?)
milkblink is offline   Reply With Quote
Old   April 2, 2023, 21:42
Janes Benth
janesbenth1 is on a distinguished road
For a Course I am required to analyse the Suddhoo-Hall Airfoil which is a common validation case as the exact potential solution can be calculated. The problem is listed in this very site as a 2D validation cases as well: https://www.cfd-online.com/Wiki/Suddhoo-Hall_airfoil heardle
With much thanks!
I can't seem to find any information on which to base my geometry and compare the results, outside of photographs. I need the geometry for this multi-element airfoil, but I don't know where to look.
janesbenth1 is offline   Reply With Quote
airfoil 2d, suddo-hall, test case, test cases, validation
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 15:13
Airfoil case setting given non-dimensional quantities choux OpenFOAM Running, Solving & CFD 0 February 21, 2016 22:59
Suddhoo-Hall Multielement Airfoil Frank Main CFD Forum 3 September 24, 2009 06:50
oscillating airfoil test case Akbar Main CFD Forum 1 July 22, 2005 11:49
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
