July 5, 2020, 06:29 |
process speed in fluent
aref
Rep Power: 6 |
Hello guys. hope you be healthy.i have two question.
When Run i processing 6m hexa element in fluent and choose 1 cores,the speed is two low,then when i set 3 cores in parallel tab the speed become more low. 1.what is the reason of decreasing speed by switching 1 to 3 cores? 2.what should i do to increase the speed of process? My OS is windows 10 64 bit My ram is 8 gb and my cpu have 4 cores and 0 hyperthread. |
July 5, 2020, 21:02 |
Lucky
Rep Power: 66 |
Check your RAM usage during calculation, you might be exceeding your RAM capacity. If you are over-capacity, increasing number of cores will slow it down since it has to load and un-load all the time.
ansys, fluent, fluent - parallel |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
FLUENT ERROR : ode 0: Process 21599: Received signal SIGSEGV. | deblina roy | FLUENT | 3 | November 22, 2019 08:40 |
Vessel filling process - CFX vs Fluent Benchmark | nav_5 | CFX | 7 | May 4, 2017 00:27 |
define process time in transient solver in FLUENT | oozcan | FLUENT | 0 | June 28, 2016 06:19 |
Fluent coupled with external process | Nitesh Goyal | FLUENT | 0 | July 10, 2007 09:35 |
