Which result file format to choose for in-house CFD code |
August 1, 2020, 03:59 |
#21 |
Alex
Rep Power: 46 |
SCNR |
August 1, 2020, 05:05 |
#22 |
Rep Power: 15 |
August 1, 2020, 05:56 |
#23 |
Arjun
Rep Power: 34 |
September 21, 2020, 19:00 |
#24 |
Pedro Costa
Rep Power: 8 |
My data layouts are simple, so I typically write field data into a raw binary format onto a single binary field using MPI I/O, which works like a charm for at least 10^10 grid points. Then I use a xdmf (http://www.xdmf.org) metadata file written with the aid of a python script to visualize the binary data in paraview. If you are interested in how I do it I can write more techical details.
In your case I would go for HDF5 or raw binary data and load it in paraview with xdmf. |
September 22, 2020, 03:32 |
#25 |
Alex
Rep Power: 46 |
Thanks for all your valuable input. Here is what I implemented for now, ugly hacks for the win I guess
The solver writes the minimum amount of values (basically just pressure and velocity) into raw binary files. For post-processing, I have a different program that can stitch this database together into a single Ensight gold database. While that may sound like a totally unnecessary step, it has some advantages to me:
I know, I know, some of these advantages may sound silly to some of you. But it works for me, at least for now. Maybe I will regret this decision in a few months or years. But that's a problem for future me. |
March 10, 2021, 14:40 |
#26 |
Alex
Rep Power: 46 |
Future me here, sooner than past me was hoping for
Turns out ensight gold has some hidden limitations, at least when combined with ParaView. I could probably patch around them, but don't really feel like it. Adding even more workarounds to an already ugly solution won't make things easier in the long run. Or is that just how programming works? So I guess it's time for CGNS+HDF5 now. Combing through the documentation for about an hour did not exactly boost my confidence levels. Wish me luck. |
March 10, 2021, 15:27 |
#27 |
Arjun
Rep Power: 34 |
While you are going through it, could you please make notes about how to use it (in simple manner). Could be then used by others.
Also do share the experiences, its learning for others. |
March 12, 2021, 09:00 |
#28 | |
Alex
Rep Power: 46 |
I just love how they found it necessary to include detailed installation instructions for Windows in their FAQ section, but not for Linux. Or at least the section for Linux is hidden so well that I haven't found it yet. Forgot to mention what kind of limitation I ran into with ParaView ensight gold reader: it fails as soon as (number of elements x number of nodes per element) is larger than 2^31 in a single part. Even if the actual number of nodes is lower because adjacent elements share the same nodes. In my case with hexa8 elements, that threshold is around 268 million elements. |
March 13, 2021, 12:36 |
#29 |
Arjun
Rep Power: 34 |
I wonder if it is possible to create our own importer. I tried to find on it but could not find much on to it.
March 13, 2021, 16:50 |
#30 |
Sayan Bhattacharjee
Rep Power: 8 |
I use ASCII VTK format for my personal projects as that works for Paraview.
I don't know if ASCII would be suitable for 10^9 cells. Binary format would be best. Regarding the multiple level requirement, I plan to write the cells from the highest layer first, and then as we go down, write only cells that are not hidden by the higher layers. It will finally look like a quadtree grid. |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
