scalar source vs species transport
Old   July 18, 2020, 04:16
Default scalar source vs species transport
harshavardhan
harsha002 is on a distinguished road
I am working on a car park ventilation project. I would like to know which equation to be used(scalar source or transport species) and would like to know why it is better comparing the other
your help is much appreciated
harsha002 is offline   Reply With Quote
Old   August 10, 2020, 19:33
Sebastian Engel
bluebase will become famous soon enough
You might need to check whether these terms are synonyms.
You likely mean, (Passive) scalar transport equations, do you? In that case such transport equation usually does not impact the flow solution but "just" takes the velocity field of the flow to compute dispersion for that passive scalar equation.
I don't have a specifc idea what a transport species is in your case. This must be defined in your solver's manual (as is the above equation type). I would guess this is used for reactive flows, where you have a fluid which consists of different species. A transport species might interact with the flow, but might not react/interact with the other species.
Which one suits your needs would require more knowledge which kind of information/quantity you need to assess.
For example, if you need to compute residence time, you usually would use a (passive) scalar transport equation.
Best,
Sebastian
bluebase is offline   Reply With Quote
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
