help in fortran code - radiation BC in 1-d SS heat transfer problem |
July 29, 2020, 03:21 |
Rep Power: 5 |
hi , iam solving 1-d steady state problem with radiation and convection on one side and constant temp. on the other side
iam writing a fortran code but i have a problem in the term of T^4 -the initial temp of the plate- any help please or any useful ref. thanks in advance |
July 29, 2020, 05:34 |
Rep Power: 5 |
a vertical metal plate exposed to fire
i supposed that Q transfered by convection and radiation to the plate i am using finite difference method |
July 29, 2020, 05:37 |
So, we are talking about 1d steady conduction (normal to the plate) with dirichlet bc on one side and convection + radiation bc on the other one, solved with finite difference. Ok
What is the problem that you have with the T^4 term? |
July 29, 2020, 06:03 |
Ok, I guess I know what your problem might be. You might want to give a look at this:
https://sci-hub.st/10.1002/nme.1620111010 |
Heat transfer convergence problem | chriss85 | OpenFOAM Running, Solving & CFD | 3 | October 14, 2023 11:12 |
Convergence in a conjugate heat transfer problem | Mohamed Abdulazim | FLUENT | 5 | March 28, 2020 15:41 |
[Other] 1D Transient heat transfer FORTRAN code | Ahmed Saeed Mansour | ANSYS Meshing & Geometry | 0 | September 11, 2018 17:33 |
Inverse and Transient Heat Transfer Problem on commercial software: is it possible? | rogbrito | CFX | 1 | January 29, 2012 17:48 |
Radiation Heat Transfer | The IFRF Heat Transfer Team | Main CFD Forum | 0 | January 31, 2000 14:02 |
