Variation in total heat flux with y+
Old   August 26, 2020, 16:08
Lightbulb Variation in total heat flux with y+
Ayush Sharma
AyushSharma is on a distinguished road
I am trying to simulate flow over a heated rotating cylinder. My configuration though is slightly different from what the conventional literature discusses - the cylinder is within a 2D region of a certain geometry where the flow takes place.
I wish to calculate the heat flux from the cylinder, and to do that I am monitoring the 'Total Surface Heat Flux'. I am using the SST k-w model, and have been carrying out y+ studies.
The value of the heat flux has been gradually decreasing with y+ (5-1). I observed that as I go from y+ = 1 to y+ = 0.5, there is a 1.17% decrease in the flux value. As I go from y+ = 0.5 to y+ = 0.4, the value increases this time (by 0.4% wrt y+ = 0.5). That comes out to be a 0.75% decrease from y+ = 1.
My question is, what could be this cause of this increase?
Note : I do not have any source for validation of the heat flux values.
AyushSharma is offline   Reply With Quote
cfd, cylinder, heated, sst k-omega
Measure of Heat Flux on a surface MathieuCrslt FLUENT 0 October 10, 2018 05:58
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Error in run Batch file saba1366 CFX 4 February 10, 2013 01:15
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Total Heat Transfer Rate & Total Surface Heat Flux Mismatch icaro FLUENT 0 November 24, 2009 07:01
