August 26, 2020, 16:08 |
Variation in total heat flux with y+
Ayush Sharma
I am trying to simulate flow over a heated rotating cylinder. My configuration though is slightly different from what the conventional literature discusses - the cylinder is within a 2D region of a certain geometry where the flow takes place. I wish to calculate the heat flux from the cylinder, and to do that I am monitoring the 'Total Surface Heat Flux'. I am using the SST k-w model, and have been carrying out y+ studies. The value of the heat flux has been gradually decreasing with y+ (5-1). I observed that as I go from y+ = 1 to y+ = 0.5, there is a 1.17% decrease in the flux value. As I go from y+ = 0.5 to y+ = 0.4, the value increases this time (by 0.4% wrt y+ = 0.5). That comes out to be a 0.75% decrease from y+ = 1. My question is, what could be this cause of this increase? Note : I do not have any source for validation of the heat flux values. |
cfd, cylinder, heated, sst k-omega |
Measure of Heat Flux on a surface | MathieuCrslt | FLUENT | 0 | October 10, 2018 05:58 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Error in run Batch file | saba1366 | CFX | 4 | February 10, 2013 01:15 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
Total Heat Transfer Rate & Total Surface Heat Flux Mismatch | icaro | FLUENT | 0 | November 24, 2009 07:01 |
