UDF for parallel use in combination with scheme possible?
Old   September 11, 2020, 06:46
Default UDF for parallel use in combination with scheme possible?
Deutschland
schwaral is on a distinguished road
Send a message via ICQ to schwaral Send a message via AIM to schwaral Send a message via Yahoo to schwaral
Hi I have the follwoing code that comuptes the variable fnew. Depending on the value ><0 I set the variable veldirect to 0 or 1. Everything works fine in serial, but not in parallel.
In parallel the printed value for veldirect is always 0. I use this variable in a scheme code that is executed every timestep. I am not sure if this will affect the parallel usage. I tried several types of this code now but I am not really sure around which line I should use host or node execution. In other codes it was more intuitive to me.
[CODE]
**** calculated fnew here ****
DEFINE_ADJUST(adjust_UDS_bc, d)
#if !RP_NODE /*execute on host or in serial */
if (fnew >= 0)
RP_Set_Integer("veldirect", 0);
else
RP_Set_Integer("veldirect", 1);
#endif
[CODE]
node_to_host_int_1(count); this is something that migth be needed as well? But again I couldnt really understand where in my case to use.
schwaral is offline   Reply With Quote
Sutile and Tricky : Drive Fluent UDF parameters directly from workbench amscosta Fluent UDF and Scheme Programming 4 July 21, 2020 16:50
Replicating Scalable Wall Function with a UDF yousefaz FLUENT 0 August 4, 2017 02:30
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
How to combine UDF and Scheme? ali hemmati Fluent UDF and Scheme Programming 3 March 19, 2011 14:45
How to implement a numerical scheme by using UDF? Furui Xiong FLUENT 0 July 29, 2010 01:30
