September 17, 2020, 15:30 |
Wave runup
Rep Power: 5 |
Hii There,
I have been practicing REEF3D for some time (running and modifying tutorial cases); But, now i need to focus on some specific cases of my interest, one of them is numerically studying the wave run-up on beaches. But, I am having a very hard time in measuring the wave runup. If any of you guys have some idea about the solution, please help me. Thanks |
November 3, 2020, 09:00 |
Wave Runup / REEF3D
Hans Bihs
Rep Power: 17 |
You could use the wsfline print out, see option P 52.
Hans |
March 17, 2021, 04:37 |
Arun Kamath
Rep Power: 13 |
Would be also interesting to see if the discharge gauge P 67 (generally used for open channel flow simulations) can provide a path to calculate the volume of overtopping past a point?
Arun X years with REEF3D |
March 17, 2021, 07:31 |
Hans Bihs
Rep Power: 17 |
Yes, P 67 should in theory work for this. Then V=Q*dt, where Q comes from P 67.
March 17, 2021, 07:36 |
Arun Kamath
Rep Power: 13 |
Yes, but in addition, for wave runup, I guess it should be integrated over the entire duration of the simulation, as unlike in open channel flow in steady state, the discharge gauges will measure both +ve and -ve values.
The net sum over the simulation is then the net run up/ overtopping (Q in Hans' post) over the duration of the simulation (dt above) to get the discharge volume over the length of the simulation and then derive the discharge per unit time.
cfd, reef3d, wave-runup |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM | hjasak | OpenFOAM Announcements from Other Sources | 2 | February 13, 2017 04:59 |
[waves2Foam] NWT wave generation problem | Alex song | OpenFOAM Community Contributions | 0 | April 24, 2016 04:54 |
IHFOAM - Wave generation with moving boundaries | Phicau | OpenFOAM Verification & Validation | 0 | May 18, 2015 04:53 |
Pls help. wave runup simulation | Bo3D | FLOW-3D | 1 | August 26, 2010 23:53 |
