If RANS are time-averaged then what does timesteps mean in simulations? |
July 21, 2021, 12:54 |
Hi all!
I am relatively new into the turbulence modeling. I started with ANSYS and tried to use the k-e model for the first time. The first thing I noticed was the existence of timesteps. This made me confused. If the RANS equations do not contain time derivatives then how do we get timesteps? My initial assumption from a RANS simulation was just to get a result somehow describing the average velocity and pressure in a domain but I got timesteps with snapshots. I googled it for a couple of hours and the best thing I found was URANS, however I haven't specified anything regarding URANS in my simplistic project. Thanks in advance! |
July 21, 2021, 14:10 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Indeed, RANS formulation is by definition for a statistically steady state, what you have to read carefully is the URANS formulation. In this latter, the equations are acted on by a different averaging and they remain time-dependent. However, be aware that the meaning of this time dependence is somehow specific only for the case of external forcing. In this forum you can find some posts with detailed answers |
July 21, 2021, 17:16 |
Rep Power: 16 |
Not an Ansys user but there are different ways to achieve steady-state solutions. If you discard temporal terms from the governing equations, after spatial discretisation, you end up in solving a (eventually big) system of non-linear equations. You can (try to) solve for it using Newton's method, I highly doubt ANSYS implemented that.
Usually the discretized equations maintain a time-derivative, the objective beeing in the case of a steady-state computation to make it vanish as fast as possible as transient is of no interest. Then time becomes fictitious and is solely used to maintain a stable numerical integration through some stability criteria (CFL<1 for explicit schemes for examples). |
July 22, 2021, 01:56 |
Joern Beilke
Rep Power: 20 |
When you go from Navier-Stokes to (U)RANS you do some averaging regarding the turbulent fluctuations. But not every transient effect is related to turbulence :-)
You can have an inlet velocity that changes with time. |
July 22, 2021, 03:44 |
#5 | |
Some texts relate RANS to the infinite time average and URANS to the average over a time step, requiring the latter to be somehow larger than any dynamic time scale related to the turbulent fluctuations, which can't be unless the unsteadiness really is slow, quasi-steady if you know what I mean. From a practical perspective, URANS is RANS with the unsteady term. The real problem here is that the turbulence model is not really different with respect to the steady case, besides its own added unsteady term. We discussed some aspects here (where, by the way, you can also see, in the comments, a link to a work by Prof. Layton that, indeed, tries to cure the URANS anomaly in the model formulation). |
rans, urans |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
Time averaged fields on a defined time range | Yann | OpenFOAM Post-Processing | 8 | August 7, 2019 04:46 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
