November 27, 2020, 03:51 |
High-Re- Model + Wall Function
Rep Power: 5 |
Hello forum users,
there is a question for which i cant find an answer in literature: I have a High- Re- turbulence-model and a wall function which switches between vscous sublayer (U+=y+) and log-layer at y+ =11,225 (Launder&Spalding or Enhanced). From literature i know, that i should place the first node in the log-law-region 30<y+<300. But since i have this wall-functions which switch between linear and log- region, i am asking myself whether its possible to use a fine mesh such that y+<=3. In my case i have very low y+- values (very thick boundary layer) and i have to use a wall function (LS-Dyna ICFD) Has someone experience in such a case? Sorry for my very bad english. Best regards. |
November 27, 2020, 06:56 |
It really depends from what you mean by High-Re turbulence model. Unfortunately, this confusing, wrong terminology spreaded a lot in the past.
You either have a turbulence model that is able to solve the viscous sub-layer (i.e., work at low y+) or you don't. Also, some models can in theory but require some specific implementations to then also work in practice. Spalart-Allmaras will work in either case without modifications. k-omega models will as well, but with modifications for the boundary conditions at walls. Most k-epsilon models (standard, realizable, RNG) WON'T work with low y+ values without modifications. Now, if I can correctly guess what software you are using (Fluent), and the turbulence model (k-epsilon), you shouldn't really bother about any of this. Still, I would probably switch to the k-omega family if there isn't any specific rationale for the k-epsilon in your case. |
law of the wall, ls-dyna, turbulence mdoel |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
3-D turbulence model with wall function | Henry | Main CFD Forum | 7 | May 19, 2006 10:40 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
