Assumption for time model with SIMPLE algorithm |
March 15, 2021, 00:24 |
Rep Power: 5 |
I´m trying to simulate a fluid damper: a double acting piston, which is moving with a sinusoidal function (10Hz) in a chamber and compresses/ expands the fluid which flows through a choke (s. picture) On the example of my system: when considering the massflow from one chamber to the other while the piston is moving and the continous change of pressure because of motion - I´m thinking this solution is unsteady (time dependent), because i have different results between two time steps - right? , so according to the literature: my temporal discretization must be 2nd order, because my physics have an unsteady behaviour (true so far?) and in case I use the SIMPLE algorithm: is it right, that it actually solves a steady state solution INSIDE the time step? So my transient behaviour would be a "compound of many steady state solution in each time step"? According to this, my question is: Do i really NEED to use the 2nd order temporal discretization or is it possible to use the 1st order? I would really appreciate if someone could explain it as simple as possible, because I´m totaly new in this theme P.S.: I used the following considerations in STAR-CCM: By using the Unsteady Implicit Solver and choosing the segregated flow, I would choose the 2nd order temporal disretization. When solving with SIMPLE, than i choose a larger time step with a higher number of inner iterations and hopefully the solution converges inside the timestep? |
simple, star ccm+, temporal discretization, time model |
ANSYS fluent vs OpenFoAM simple algorithm/ PIMPLE algorithm | gentodin | Main CFD Forum | 1 | December 24, 2020 02:43 |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
Looking for simple, robust interface tracking algorithm | ThomasTC | Main CFD Forum | 7 | September 26, 2016 05:35 |
SIMPLE algorithm for two-phase | rks171 | Main CFD Forum | 4 | April 20, 2012 09:02 |
outflow boudary condition in SIMPLE algorithm | dallybird | Main CFD Forum | 0 | March 6, 2003 11:55 |
