S-shape Intake Diffuser : Boundary Condition
Old   October 11, 2020, 13:40
Post S-shape Intake Diffuser : Boundary Condition
Rishabh Jaiswal
cfd.rishabh is on a distinguished road
https://www.cfd-online.com/Forums/at...1&d=1602436223
How to define BC for s-shaped duct intake at outlet ???
https://www.cfd-online.com/Forums/at...1&d=1602437017
CFD simulation for intake [s-shaped] which is connected to gas-turbine [in real condition] . It operates at different altitudes [Po & To varring with height].
[/B]but it is not able to define the proper boundary condition at the outlet of the intake.[/B] ................. tried with Pressure outlet (70120 Pa) condition is not appropriate because it does not match the practical condition ........ is their proper way of defining it [at the outlet side], which matches the practical condition at outlet ?
Engine Details : m = 2.5 Kg/s [at ideal condition] {this much detail I know about gas turbine} at rpm = 4200
BC
pressure far field : Ma = 0.5 , Po = 70120 Pa , To = 268.5 K
Outlet BC ???????? [which is at AIP (Aerodynamic Interface Plane) as show in fig. ]
cfd.rishabh is offline   Reply With Quote
Old   November 21, 2020, 22:27
sam
mczero57 is on a distinguished road
Hi Rishabh:
At the AIP, the flow is subsonic, so the bc is going to be oinfluenced by both engine (downstream) and upstream (s-duct). As a first shot, you can impose a mass flow boundary condition at exit - thisis equivalent to prescribing an average exit static pressure at the AIP.
HTH,
Sam.
mczero57 is offline   Reply With Quote
Cyclic boundary condition in foam-extend 4.0 rellumeister OpenFOAM Pre-Processing 2 March 3, 2020 08:03
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 10:20
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
