December 24, 2020, 13:59 |
Conjugate Heat Transfer B.C.
Rep Power: 5 |
Hello forum,
i am currently trying to do a coupled cf-thermal- simulation: I have a pipe with a hot water flowing inside. The pipe-wall is 2 mm thick and i am interested in the steady- state temperature-field in that wall. Which boundary condition should i apply on the outer wall of the pipe? Lets say the pipe-wall is made of aluminium and the outer medium is air at some temperature. How do engineers solve that kind of problems? Best regards. |
December 25, 2020, 12:03 |
Rep Power: 5 |
Thank you!
I will try it out. |
cfd, conjugate, heat, transfer |
No conjugate heat transfer between solid (cast iron) and fluid (water) part | Rajaero | FLUENT | 5 | June 25, 2023 03:07 |
Conjugate Heat Transfer | Gowrav | FLUENT | 0 | October 10, 2018 05:55 |
No conjugate heat transfer between solid (cast iron) and fluid (water) | Rajaero | Main CFD Forum | 1 | August 23, 2018 13:01 |
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? | MaxHeat | FLUENT | 4 | September 14, 2017 10:44 |
conjugate heat transfer boundary condition | Souviktor | FLUENT | 6 | April 6, 2014 17:34 |
