How do Euler solvers solve turbulence without any turbulence model? |
January 23, 2021, 02:09 |
Sayan Bhattacharjee
Rep Power: 8 |
In NS solvers, we need turbulence models like RANS, URANS, k-omega, k-sst etc.
But, I have not seen any turbulence models being used in compressible Euler solvers. As shown in the picture, Euler solvers can directly compute extremely complicated turbulent flows, but it doesn't need any turbulence model. Why is it like that? Also, is it a good thing or a bad thing that it doesn't need any turbulence model? Where would this be useful or harmful? Thanks and regards ~sayan |
January 23, 2021, 03:32 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Using Euler equation for compressible flows is typical in shock waves problems. In such a case, the main interest is not in turbulence but in capturing shock waves. This is done generally by using specific schemes that mimics the presence of dissipation by additional terms, as same as happens in turbulence model. Using NSE you can solve turbulence without any turbulence model, provided that you are able to solve in a DNS manner |
January 23, 2021, 03:37 |
#3 | |
Sayan Bhattacharjee
Rep Power: 8 |
Which schemes could we use to accurately mimic the presence of dissipation? The paper from which I took the image, shows that MWENO-P was better in capturing the instability and turbulence than WENO-P and WENO-JS. Are these the methods you were mentioning? Thanks |
January 23, 2021, 03:55 |
Rep Power: 71 |
Yes, you should refer to the ILES literature
January 23, 2021, 06:54 |
Sayan Bhattacharjee
Rep Power: 8 |
January 23, 2021, 07:04 |
#6 | |
Rep Power: 71 |
Have a check at the CTR publications https://ctr.stanford.edu/ you will see many type of applications for shock-waves flows. Generally, WENO/TENO, schemes based on monotonicity-preserving flux reconstruction, are in a form suitable for ILES formulation. Have also a look to the home page of Len Margolin and that of Nikolaus Adams. |
January 23, 2021, 07:07 |
#7 | |
Sayan Bhattacharjee
Rep Power: 8 |
Ok, thanks professor! That helps a lot. |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 18:19 |
New turbulence model in OpenFOAM 5 with porosity scalar | shinjanghosh | OpenFOAM Programming & Development | 0 | January 15, 2020 00:06 |
Implement an les turbulence model | pante | OpenFOAM Programming & Development | 19 | December 5, 2014 16:16 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
