January 28, 2021, 08:35 |
Turbulent intensity at inlet
Rep Power: 5 |
I am trying to simulate flow inside a 2d nozzle. I was having issues with high turbulent intensity values. However, I found that the turbulent intensity at the inlet is about 15% and is uniform along the inlet (vertically). How is this value determined? As in the inlet boundary conditions, a turbulent intensity of 5% is set. |
January 29, 2021, 08:54 |
Rep Power: 5 |
Hello
Assuming 5% turbulent intensity should be enogh to get fully developed turbulent flow at the inlet. However, The turbulent intensity at the inlet can be also estimated using the Raynolds number. See here: https://www.cfd-online.com/Wiki/Turbulence_intensity |
January 29, 2021, 10:08 |
Rep Power: 5 |
Thank you very much for your response. However, I do not have an issue determining the turbulent intensity at inlet. As boundary conditions, I have set turbulent intensity at the inlet to be 5%. However, after running the simulation, when trying to plot the turbulent intensity values at the inlet, I am getting 15% instead of 5%. I'm not sure why this is |
value of turbulent intensity at inlet | eng.abdul | Fidelity CFD | 11 | February 1, 2018 03:09 |
turbulent intensity for heat exchangers | soheil1991 | FLUENT | 1 | January 5, 2018 05:10 |
inlet for turbulent boundary layer | treer | FLUENT | 0 | February 12, 2012 00:54 |
Turbulent intensity for pressure Outlet Boundary condition | Mohsin | FLUENT | 1 | April 30, 2010 10:36 |
Turbulent intensity | swe704 | Main CFD Forum | 0 | November 13, 2009 03:42 |
