February 15, 2021, 00:43 |
under ventilated compartment
So I am modeling an extremely underventilated experiment. I tried to do that with FDS, but the combustion models are one and two-step reactions, and fast chemistry assumption is used. That leads to unrealistic low compartment temperatures because the burning happens at the vent. I am considering starting with fire foam since it has more combustion models. If I used the diffusion model, will that solve the issue? Also, I have limited time to complete the project. OR should I stick to FDS, and try the different turbulent models. That might affect the mixing time which depends on the turbulent viscosity. Also, diffrent autoignition temperature might be used. Thanks |
fire dynamics simulations, firefoam, openfoam, under ventilated |
Fire dynamic Simulator under ventilated compartment | Waseem_FDS | Main CFD Forum | 0 | January 17, 2021 19:48 |
Mixed Convection in Compartment - dimensionless parameter & solver | eaglemckenna | FLUENT | 0 | April 20, 2016 06:59 |
[blockMesh] compartment fire meshing | abtin_c4 | OpenFOAM Meshing & Mesh Conversion | 0 | November 5, 2014 16:06 |
Study of poorly ventilated compartment fires in ANSYS | adnan.iitgn | ANSYS | 0 | September 29, 2011 17:59 |
Modeling a compartment with circulation (by a fan) | neilpan | CFX | 7 | November 11, 2009 00:14 |
