Difficulty in simulating pressure driven flow using pimpleFoam
Old   March 2, 2021, 00:47
Post Difficulty in simulating pressure driven flow using pimpleFoam
parth
parthigcar is on a distinguished road
Dear community,
I am very new to OpenFOAM as well as to CFD. I am trying to simulate pressure-driven flow (geometry is similar to an inverted L shape, where the inlet is at the bottom), where we apply time-dependent pressure at the inlet and measuring the mass flow rate at the outlet. While I am able to run the simulation without any error. However, the outlet mass flow rate is 2 orders lower than lumped simulation. Here, I have taken sodium as working fluid (however I assume that wont make any difference, since I have divided the pressure with the sodium density, and provided appropriate viscocity in transport properties.)
I would be grateful if any of you can point out where I am doing wrong. My velocity and pressure boundary is as follows:
Velocity boundary conditions:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            pressureDirectedInletOutletVelocity;
        inletDirection  uniform (0 0 1);
        value           uniform (0 0 0);
    walls
        type            noSlip;
    wedge1
        type            symmetry;
    wedge2
        type            symmetry;
    top_walls
        type            noSlip;
    outlet
        type            pressureInletOutletVelocity;
    interface3
        type            empty;
    interface4
        type            empty;
Pressure boundary conditions:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            uniformTotalPressure;
        p0 table
    outlet
        type            totalPressure;
        p0              uniform 0;
        value           uniform 0;
    walls
        type            zeroGradient;
//          type            fixedFluxPressure;
//          value           uniform 0;
    top_walls
        type            zeroGradient;
//          value           uniform 0;
        wedge1
        type            symmetry;
        wedge2
        type            symmetry;
		defaultFaces
		  type empty;
		interface3
		  type empty;
		interface4
		  type empty;
Transport properties:
transportModel Newtonian;
// Laminar viscosity
nu              2.16e-04;
// Thermal expansion coefficient
beta           3.0164e-4;
// Reference temperature
TRef            873;
// Laminar Prandtl number
Pr              0.0044;
// Turbulent Prandtl number
Prt             0.85;
parthigcar is offline   Reply With Quote
mass flow rate, pimplefoam, pressure driven flow
pisoFOAM (LES) - internal pipe flow - convergence gu1 OpenFOAM Running, Solving & CFD 0 January 11, 2018 16:39
Compressible Pressure Driven Flow mateiu2003k OpenFOAM Running, Solving & CFD 1 August 24, 2016 06:00
Discrepancy in Pressure Driven Flow Behaviour in 211 vs 221 cdm OpenFOAM Running, Solving & CFD 5 December 17, 2013 07:48
Boudaries for bouynat driven flow with additional mass flux at inlet Charon CFX 2 April 27, 2013 08:02
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 06:52
