March 8, 2021, 13:33 |
Hypersonic Flow Simulation problem
Ash
Rep Power: 5 |
I am currently modelling a basic re-entry flow simulation around a body, but I am not getting the results that I should be expecting, my temperature contours and velocity contours are showing no variation along the body after >15000 iterations. My initial conditions are as follows: BC: Pressure Far Field = Mach 15 No slip wall (around the body) S-A Turbulence Model Ideal Gas Viscosity - Sutherlands Gauge Presure - 0 Steady Density Based solver I'm quite confused why there is no variation in velocity contours or temperature at all, so any help would be very much appreciated. |
Problem with FsiFOAM simulation of beams (2-4 beams) in a steady simple shear flow | Aliiiii | OpenFOAM Running, Solving & CFD | 1 | February 27, 2019 12:26 |
Pipe flow simulation problem with pisoFoam: not getting parabolic profile | sahmed | OpenFOAM Running, Solving & CFD | 1 | September 7, 2016 14:00 |
Problem with pipe flow simulation with wedge shaped domain and recirculation bubbles | sahmed | OpenFOAM Running, Solving & CFD | 0 | August 17, 2016 14:56 |
Overflow in hypersonic flow simulation | badboyz31 | CFX | 13 | March 8, 2014 04:33 |
[CFX] Simulation of Flow Separation in a rectangular diffuser - Convergence Problem | anon_b | CFX | 11 | May 6, 2012 20:16 |
