Creating a Report Definitions Surface Plane
Like Tree1Likes
  • 1 Post By LoUcAsss
Old   March 11, 2021, 08:30
Default Creating a Report Definitions Surface Plane
Rida
Ben_Hmouda is on a distinguished road
Hi guys,
I am looking for a recommendation in Ansys fluent for creating a (Report Definitions) surface plane in a fluid domain without including the pipe thickness (solid domain), as in the picture. (the first plane is the inlet that just includes the fluid domain. In contrast, the second plane includes both fluid and solid domains. In other words, how can I create a surface plane that just represents the fluid domain in any section of the pipe?
Your help is highly appreciated.
Ben_Hmouda is offline   Reply With Quote
Old   March 15, 2021, 03:44
lucas s
LoUcAsss is on a distinguished road
You can use the function Iso-surface in the tab Setting up domain go to Surface > Create. Within the window select the interior of the fluid cell zone and use the correct direction in the variable list Mesh > x_coordinate (or y or z), define the coordinate.
This should do the job.
Cheers,
Lucas
Ben_Hmouda likes this.
LoUcAsss is offline   Reply With Quote
Old   March 15, 2021, 12:18
Rida
Thank you so much, Lucas, for your recommendation; I will try to apply it.
Best wishes,
Rida
Writing report files and creating report definitions. cfd_worker99 FLUENT 3 June 12, 2020 12:55
Creation of a plane surface with the TUI EmiS FLUENT 2 August 31, 2016 08:11
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Bug: Surface Integral->Sum w/cut plane and x-face-area agodfrey FLUENT 0 June 9, 2009 13:11
