March 17, 2021, 14:19 |
Ansys Fluent Joining separate solid bodies
Rep Power: 5 |
I have a 2D geometry of three separate surfaces. The outer ring and very center is solid, and the middle is a fluid. Problem is that when I load up fluent, fluent is combining the two solids as one contact region thus there are 3 separate walls as one individual wall which I believe I need each wall to be separate. Attached are images https://imgur.com/a/FnN73Qz
I will be applying radiation and heat generation to the inner solid and a temperature to the very outer diameter |
March 18, 2021, 12:28 |
Rep Power: 5 |
Is nobody able to help with this?
ANSYS Fluent rotation of SOLID drum filled with water | coms0 | FLUENT | 0 | October 26, 2019 09:49 |
How to define a hole as boundary condition in Ansys Fluent using Fluent an mesh only? | Nagu Sattenapalli | CFD-Wiki | 0 | August 12, 2019 04:03 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 12:07 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
