Residuals start increasing after decreasing to a very low value |
April 18, 2023, 13:24 |
#21 | |
Arjun
Rep Power: 34 |
Nope. It depends on the solver. Here in the OP we are talking about residual remaining after the solution is obtained and descretisation is applied. Accuracy is with respect to exact or benchmark solution. So it is possible for solver to produce a solution that has higher residual but is more accurate. This is the whole point. The residual in this context is different than what you have in mind. |
April 18, 2023, 13:25 |
#22 | |
Arjun
Rep Power: 34 |
Yes very much.
April 18, 2023, 13:46 |
#23 | |
Filippo Maria Denaro
Rep Power: 71 |
There is no sense in this discussion if we do not formalize the object of the issue. - The numerical solution, by definition it satisfies the discrete set of equations A_d(fnum)=q - The exact solution, by definition it satisfies the original PDE A_pde(fex)=q. - Order of accuracy is the main term in the local truncation error of the whole equations. It seems you are talking about point #1, that is you select a numerical solution f_num_app (that is not fnum) and does not satisfy the discrete set of equations A_d(f_num_app)-q=res. And you are stating that f_num_app is a better approximation of fex than fnum. And that a solution f_num_app2, producing a res2>res would be still better. Therefore, we are talking about the discretization error, not about the local truncation error. Am I right? But that has nothing to do with the accuracy order. |
[Tutorials] Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Community Contributions | 171 | February 20, 2024 02:55 |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
Cannot find functionObject file residuals | vava10 | OpenFOAM Pre-Processing | 2 | November 14, 2020 12:21 |
Residuals increasing after few iterations | Aijiazi | FLUENT | 5 | September 28, 2020 08:46 |
Mesh size and solver residuals... | Scott | CFX | 5 | December 15, 2008 17:10 |
