udf calculate
Old   April 6, 2021, 20:48
Default udf calculate
HOJUN YU
hobing is on a distinguished road
hi all,
i'm using UDF
Inlet conditions are mass flow,
and we're using a turbulence (standard k-epsilon) models.
The machine I use is 196 cores.
but initial and iteration too slow..
The grid is 60 million in total.
more than 100 million didn't take this much.
I think my udf's mpi code is wrong, so what can I do to speed up?
Even if it's not a problem with the udf code, what is the way to speed up the calculation? Besides reducing the grid!
give me a lot of ideas to speed up the calculations, you smarts!
thank you :0
hobing is offline   Reply With Quote
How to calculate the curvature in UDF Xinqiang Fluent UDF and Scheme Programming 9 December 16, 2022 02:28
How to calculate the number of if conditions executed in a fluent udf? Shubhamp Fluent UDF and Scheme Programming 56 January 23, 2020 18:19
sharing code to calculate PMV, PPD and PD in fluent using UDF simon02200059 Fluent UDF and Scheme Programming 2 June 24, 2019 01:02
Problem with a simple UDF to calculate cell-averaged particle values kmayank FLUENT 1 January 18, 2011 01:40
How to calculate the mass flow rate with UDF ? HP FLUENT 0 January 10, 2005 19:38
