Mercurial
Rep Power: 3 ![]() |
Hi everyone,
I 'm trying to calculate Nusselt number on the cylinder surface in CFD post. But I got one problem, when i calculate Nu ave on the cylinder surface, i use Tdiff=massFlowAve(Temperature)@outlet-massFlowAve(Temperature)@inlet Tbulk=massFlowAve(Temperature)@inlet+(x+0.4846[m])*Tdiff/0.872[m] h=Heat Flux/(Temperature-Tbulk) Nu=h*0.0235[m]/0.0254[W m^-1 K-1] Nuave=areaAve(Nu)@cylinder with x is my cordination of cylinder, -0.4846 inlet, 0.872=(inlet->outlet) 0.0235: hydraulic diameter, 0.0254: thermal conductivity My problem is the result from this which is negative, whereas my areaAve temperature on the cylinder is higher than Tbulk. My heat flux is positive, Temp out is higher than temp in. Please, Anyone calculated the Nusselt on the cylinder(or Pin-fin) can help me understand and fix this problem. Thanks . |
Display Modes | |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 19 | June 11, 2020 15:54 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 90 | October 3, 2019 07:01 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 14:53 |
