May 28, 2021, 17:35 |
InterFoam to Model Water Flow
NA
Hi Foamers.
I'm pretty new to OpenFOAM. I have spent almost three weeks to setup a simple model using a model created snappyHexMesh. What I'm trying to do is simulate water flow over grading control object depicted by the block mesh. When I run this model, I don't see water is flowing from inlet to outlet on the grading control object. Instead, I see water flow on the wall. I have researched to resolve this issue, but I couldn't. Can you please help me? Thank you. |
OpenFOAM - Apparently "not conservative" flow rate with interFoam | foamF | OpenFOAM Running, Solving & CFD | 4 | September 4, 2019 15:02 |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
model the sediment flow in moving water pipe | kikoka | OpenFOAM Running, Solving & CFD | 0 | April 4, 2019 04:10 |
Flow water in channel with zero speed | illia | Fluent Multiphase | 0 | March 21, 2018 07:30 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
