Simulation NACA65A004
Like Tree1Likes
  • 1 Post By flotus1
Old   June 2, 2021, 05:33
Default Simulation NACA65A004
Mercurial
Techies is on a distinguished road
Hi guys,
I'm trying to simulation NACA64005
But the trailing edge of airfoil is so small(just 0.0007mm at c=75mm). It makes mesh too bad. I don't know how to connect it and still remains the characteristic of the airfoil.
So, how to drawn the trailing edge of this airfoil. Does anyone know about the formulation to trailing edge of naca airfoil ?
Thanks all.
Techies is offline   Reply With Quote
Old   June 2, 2021, 08:28
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
If the blunt part of the trailing edge is this tiny compated to the overall size of the airfoil, you won't change any flow characteristics by just making the trailing edge sharp.
Even if that should have any impact on the flow, it is smaller than the impact from a suboptimal mesh in that region.
Techies likes this.
flotus1 is offline   Reply With Quote
Old   June 2, 2021, 08:39
Mercurial
Can i neglect some point near airfoil's tail to make trailing edge bigger ?
Old   June 2, 2021, 08:52
flotus1's Avatar
Alex
A blunt trailing edge should be formed by 2 points in the airfoil profile. Omitting either of them should turn the trailing edge sharp. Feel free to share some images to confirm.
Convergence Problem - Transient Simulation gemxx Main CFD Forum 0 July 15, 2018 09:36
Mapping Field Data for Mesh Regions from Another Simulation veterator OpenFOAM Pre-Processing 1 July 10, 2018 05:28
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 02:28
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 15:06
setting up a simulation with multiple interactions phandy OpenFOAM Running, Solving & CFD 1 October 6, 2014 03:16
