August 4, 2021, 09:14 |
Moldex3D: I need help with Moldex3D commands
Rep Power: 13 |
I am using Moldex3D for the simulation of the injection moulding process. I did the simulation, but I need to know the commands of the following tasks: 1) Importing an external geometry 2) Select all the lines of the imported geometry 3) Give the selection of 2), the attribute of "cooling channel" as in the "Model-Attribute" menu. 4) Select "check cooling system" (for automatic creation of a Moldbase and placement of water line inlets and outlets. 5) Command "specify face" and select the inlet face. 6) Mesh all the elements (piece + waterlines + moldbase), as within the "Mesh" menu. I don't need anything too detailed. I just would like to know the commands, as I will search for them in the Moldex3D documentation and read about them and their syntax. I thank you all in advance, Best regards, Andrade Silva |
USER Commands - comands execution order not respected | Benyounes | FLUENT | 1 | September 18, 2020 09:44 |
Writing Fluent Journal files Using TUI commands. | Farid2817 | FLUENT | 1 | September 8, 2019 03:18 |
Save picture from Execute commands and journal files | FJSJ | FLUENT | 0 | January 29, 2015 08:56 |
Please explain this commands. | sri31049 | FLUENT | 3 | March 20, 2009 04:38 |
OpenFOAM14 for Mac OSX Darwin 104 | gschaider | OpenFOAM Installation | 118 | July 20, 2008 05:19 |
