Moldex3D: I need help with Moldex3D commands
Old   August 4, 2021, 09:14
Default Moldex3D: I need help with Moldex3D commands
lopesdasilva is on a distinguished road
I am using Moldex3D for the simulation of the injection moulding process. I did the simulation, but I need to know the commands of the following tasks:
1) Importing an external geometry
2) Select all the lines of the imported geometry
3) Give the selection of 2), the attribute of "cooling channel" as in the "Model-Attribute" menu.
4) Select "check cooling system" (for automatic creation of a Moldbase and placement of water line inlets and outlets.
5) Command "specify face" and select the inlet face.
6) Mesh all the elements (piece + waterlines + moldbase), as within the "Mesh" menu.
I don't need anything too detailed. I just would like to know the commands, as I will search for them in the Moldex3D documentation and read about them and their syntax.
I thank you all in advance,
Best regards,
Andrade Silva
lopesdasilva is offline   Reply With Quote
USER Commands - comands execution order not respected Benyounes FLUENT 1 September 18, 2020 09:44
Writing Fluent Journal files Using TUI commands. Farid2817 FLUENT 1 September 8, 2019 03:18
Save picture from Execute commands and journal files FJSJ FLUENT 0 January 29, 2015 08:56
Please explain this commands. sri31049 FLUENT 3 March 20, 2009 04:38
OpenFOAM14 for Mac OSX Darwin 104 gschaider OpenFOAM Installation 118 July 20, 2008 05:19
