Digital filtering inflow turbulence generation and artificial shocks |
August 18, 2021, 21:48 |
Greetings,
I am using the digital filtering technique proposed by Touber & Sandham (2009) for inflow turbulence generation for a supersonic turbulent boundary layer over an isothermal wall under the WRLES framework. However, I've encountered a shock-like structure right at the leading edge. The figure below is a time-averaged pressure field. p.png In the figure, one can see a shock-like structure standing there right near the inflow plane. This artificial shock creates huge pressure fluctuations which survive all the way to the downstream, causing the prediction of pressure fluctuations very poor compared to the corresponding DNS data. I couldn't find a way to mitigate this structure and to reduce the pressure fluctuations. I am wondering has anyone ever used this inflow technique before, and encountered a similar issue? Or any suggestions/thoughts? Thanks ahead. Last edited by TurbJet; August 22, 2021 at 00:24. |
September 3, 2021, 04:15 |
Rep Power: 11 |
Yes, I have seen the same issues with a turbulent inflow using a filtering technique for supersonic flow.
The issues are mainly caused by three factors:
September 3, 2021, 17:14 |
#3 | |
But from what I observed, the pressure fluctuations is actually strongly coupled with velocity fluctuations (not surprising actually), which is directly related to the Reynolds stresses provided. Somehow I found the prescribed integral length scales do not have that significant impact on the fluctuations than the Reynolds stresses. Anyway, I tried to "artificially" reduce the magnitude of the Reynolds stresses, and the pressure fluctuations did reduce as well. However, I've observed a shifting in overall pressure magnitude as the flow develops downstream. Don't know why. I use profiles from DNS for the thermodynamic quantities. Not sure using some other relations (e.g., Waltz relation) would give improvement. |
fluctuations, inflow generation, thermodynamics, turbulent boundary layer |
