September 20, 2021, 18:44 |
Wrong Pressure Distribution
Shravana
Rep Power: 4 |
Hi all! I have conducted an ICFD analysis of a 3 mm cooling channel using a Steady-State Solver. The image below is the fluid pressure result for boundary conditions: Inlet velocity = 1195.586 mm/s and Outlet pressure = 0 MPa.
As seen here, the pressure results are not consistent especially in the region near the inlet and the outlet. Can anyone help me recognize what could the reason be for this? |
September 21, 2021, 07:37 |
Guven Nergiz
Rep Power: 5 |
Do you map the pressure values to Ls-Dyna mesh?
September 21, 2021, 07:39 |
Shravana
Rep Power: 4 |
No, I did not map any pressure values. This result is based on the boundary conditions only.
September 21, 2021, 07:48 |
Guven Nergiz
Rep Power: 5 |
Because it looks LS-Dyna Pre-Post, maybe this is the problem. Otherwise I think its about the mesh...
September 21, 2021, 07:53 |
Shravana
Rep Power: 4 |
Yes, it is LS-Dyna but I did not map any pressure values. I have refined the mesh to 0.25 mm element size.
I have investigated a simple cylinder too and it gives me correct results. |
cfd, cooling, pressure |
Correct pressure distribution but wrong aerodynamics coefficients | Aerospace | OpenFOAM | 11 | December 12, 2012 05:05 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Pressure distribution over an airfoil-help | Andrew Parker | FLUENT | 4 | February 13, 2002 11:51 |
Effects of gravity in pipe - pressure distribution | Anthony Wachs | FLUENT | 2 | July 25, 2001 07:07 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
