openfoam eror
Old   October 19, 2021, 07:34
Default openfoam eror
hari charan
saicharan662000@gmail.com is on a distinguished road
i am solving air and water mixture using interFoam solver using compressible interfom test case(depth charge 2D).
I didn't understand the error I got. can anyone help me regarding this error.
I am attaching the files below.
Create time
Create mesh for time = 0
PIMPLE: No convergence criteria found
PIMPLE: No corrector convergence criteria found
Calculations will do 2 corrections
PIMPLE: Operating solver in transient mode with 2 outer correctors
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 5.7547193e-06, No Iterations 19
time step continuity errors : sum local = 0.003950958, global = -1.7391304e-06, cumulative = -1.7391304e-06
Courant Number mean: 0.0040870852 max: 0.063914988
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.00011904762
Time = 0.000119047619
PIMPLE: Iteration 1
MULES: Solving for alpha.water
Phase-1 volume fraction = 0.86956625 Min(alpha.water) = 0 Max(alpha.water) = 1.0504699
Phase-1 volume fraction = 0.86956729 Min(alpha.water) = 0 Max(alpha.water) = 1.099891
GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 3.2933494e+38, No Iterations 1000
time step continuity errors : sum local = 7.7972453e+35, global = 1.0611186e+22, cumulative = 1.0611186e+22
GAMGPCG: Solving for p_rgh, Initial residual = 1.0405737e-10, Final residual = 1.0405737e-10, No Iterations 0
time step continuity errors : sum local = 7.9042869e+35, global = 1.0434781e+22, cumulative = 2.1045967e+22
PIMPLE: Iteration 2
Phase-1 volume fraction = -5.3073264e+21 Min(alpha.water) = -9.3851186e+35 Max(alpha.water) = 9.447862e+35
Phase-1 volume fraction = -3.6251029e+36 Min(alpha.water) = -8.6122374e+56 Max(alpha.water) = 5.1339295e+56
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam:ICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) at ??:?
#4 Foam:ICSmoother:ICSmoother(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:?
#5 Foam::lduMatrix::smoother::addsymMatrixConstructor ToTable<Foam:ICSmoother>::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:?
#6 Foam::lduMatrix::smoother::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::dictionary const&) at ??:?
#7 Foam::GAMGSolver::initVcycle(Foam::PtrList<Foam::F ield<double> >&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::lduMatrix::smoother>&, Foam::Field<double>&, Foam::Field<double>&) const at ??:?
#8 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#9 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#10 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/interFoam"
#11 Foam::fvMatrix<double>::solve() in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/interFoam"
#12 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/interFoam"
#13 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#14 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/interFoam"
Floating point exception (core dumped)
saicharan662000@gmail.com is offline   Reply With Quote
Old   October 19, 2021, 12:46
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
The solver was more-or-less setup successfully and it tried to do its first iteration. It eventually hit a floating point error but the residuals are not looking so good so it probably just diverged.
LuckyTran is offline   Reply With Quote
Old   October 20, 2021, 00:44
hari charan
Can you please tell me what should I do to get solution converge.
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
OpenFOAM Foundation Releases OpenFOAM v2.3.0 opencfd OpenFOAM Announcements from OpenFOAM Foundation 3 December 23, 2014 03:43
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
