nutkRoughWallFunction ERROR
Old   November 17, 2021, 13:43
Default nutkRoughWallFunction ERROR
Elena Espana
reespanau is on a distinguished road
Hi Foamers!
I'm working on a simulation using pisoFoam, I'm using the nutkRoughWallFunction with the following parameters:
The roughness height ks is required as the input of most nut wall equations, to assure a rough wall log layer between the center of the first near-bed grid cell and the wall. In our case, the first near-bed grid cell is equal to 5-cm, ks is 10-cm, and zo is approximately 2*ks (20-cm).
FoamFile
version 2.0;
format ascii;
class volScalarField;
object nut;
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0;
boundaryField
bed
type nutURoughWallFunction;
Ks uniform 0.1;
Cs uniform 2;
Cmu 0.09;
kappa 0.41;
E 9.8;
roughnessFactor 1;
value $internalField;
topWall
type slip;
sideRight
type slip;
sideLeft
type slip;
inlet
type fixedValue;
value uniform 1e-06;
out
type zeroGradient;
AND I GOT THIS ERROR:
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type LES
Selecting LES turbulence model SpalartAllmarasDDES
Selecting LES delta type smooth
Selecting LES delta type cubeRootVol
Selecting patchDistMethod meshWave
LES
model SpalartAllmarasDDES;
turbulence on;
printCoeffs on;
delta smooth;
dynamicKEqnCoeffs
filter simple;
cubeRootVolCoeffs
deltaCoeff 1;
PrandtlCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Cdelta 0.158;
vanDriestCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Aplus 26;
Cdelta 0.158;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Ce 1.048;
sigmaNut 0.66666;
kappa 0.41;
Cb1 0.1355;
Cb2 0.622;
Cw2 0.3;
Cw3 2;
Cv1 7.1;
Cs 0.3;
CDES 0.65;
ck 0.07;
No MRF models present
No finite volume options present
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 logf32x in "/lib/x86_64-linux-gnu/libm.so.6"
#4 Foam::nutURoughWallFunctionFvPatchScalarField::yPl us(Foam::Field<double> const&) const at ??:?
#5 Foam::nutURoughWallFunctionFvPatchScalarField::nut () const at ??:?
#6 Foam::nutWallFunctionFvPatchScalarField::updateCoe ffs() at ??:?
#7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::evaluate() in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/pisoFoam"
#8 Foam::LESModels::SpalartAllmarasDES<Foam::Incompre ssibleMomentumTransportModel<Foam::transportModel> >::correctNut() at ??:?
#9 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/pisoFoam"
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/pisoFoam"
Floating point exception (core dumped)
Can anyone help me to understand and solve the error, please?
Thanks
University of Texas
reespanau is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
