fvOptions in parallel or alternative function/solver |
November 22, 2021, 10:58 |
George
Rep Power: 5 |
Hi all,
I have an interesting case where I have a temperature dependent heat source. The heat source is dependent on the average temperature of a cellzone or set of cells and the power source change is significant and depends on the last time (dt) and power as well. I tried using fvOptions to simply take the average and write it out to a text file to read in on the next timestep, However, when I run fvOptions in parallel, I realize it is only doing this for the average of the partitioned mesh and not the whole set of cells. So here are a few questions that I have: Can I reference cells in fvOptions that aren't in the decomposed section? What order are functions (which I believe I can reference the whole mesh or just cellzones) executed, before or after fvOptions? Also any reference or guide on how to write a function would be very helpful. Worse comes to worse, can I write a custom solver that would accomplish this and have an input dictionary specify the cellzone/cellset of interest? I am able to work with any version of OpenFOAM, but my first few attempts were on of8. If there is an easier way to do this on of-2106 or of9, I would like to try it. Any help is appreciated, thank you! |
fvmodels, fvoptions, heat source |
User fortran to input/output file in a parallel run | doublestrong | CFX | 5 | March 31, 2017 08:15 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Any Parallel install procedure on Mac OS | JinZhiyi | SU2 Installation | 2 | March 11, 2014 01:12 |
simpleFoam in parallel issue | plucas | OpenFOAM Running, Solving & CFD | 3 | July 17, 2013 11:30 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
