CFD for combustion chamber in turbofan engine |
December 17, 2021, 03:49 |
Tom Ola
Rep Power: 4 |
Dear All,
Hope you are all doing well. The simulations on CFD has given some couples of errors but now I am faced with the error on the ''non-zero exit code of:2'' when trying to burn dual fuel together. please can you advice on what I should do? Thank you. |
December 17, 2021, 09:49 |
Lucky
Rep Power: 66 |
Workbench couldn't fetch the solution. That means there was a problem during the calculation. You need to fix the CFD. So go back to those couple of errors. What are they?
December 17, 2021, 10:20 |
Tom Ola
Rep Power: 4 |
Thank you Lucky.
I will try to check it again. I have already done that to see what went wrong initially but still without a clue. Regards. |
General recommendations for CFD hardware [WIP] | flotus1 | Hardware | 18 | February 29, 2024 12:48 |
Mesh Errors for an Turbofan Engine | syed123 | ANSYS | 0 | March 12, 2021 21:05 |
CFD of combustion process of Homogeneous Charge Compression Engine (HCCI) | kelvinlim | Main CFD Forum | 2 | January 26, 2012 22:19 |
CFD code for IC engine modelling | lost.identity | Main CFD Forum | 5 | November 2, 2011 12:08 |
Automotive Engine Design using CFD . . | Cameron Goodale | Main CFD Forum | 2 | October 2, 2003 10:13 |
