How do we know the simulation was switched to LES, while using DES model |
February 18, 2022, 01:51 |
Ajiazi
Rep Power: 5 |
I am using Detached eddy simulation model (DES) in fluent. I want to make sure that the simulation is being switched to LES model away from the wall. How do we know that this swtich happen. Is there any quantity/idicator that can prove that this switch is happen.
Thank you |
des, fluent, les, switching, turbulence model |
Identifying location of turbulence model shift in DES or SST models | Jonassvantesson | Main CFD Forum | 2 | October 9, 2020 11:52 |
Long simulation time using LES turbulence model? | tmy | CONVERGE | 2 | September 7, 2018 09:53 |
Simulation Crashing When Gas Model Switched to Redlich-Kwong Soave | JonesIV | CONVERGE | 1 | August 27, 2018 12:08 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
[OpenFOAM 1.6] How to run a simulation based on either DES or LES? | imranazizahmed | OpenFOAM Running, Solving & CFD | 1 | January 29, 2013 01:27 |
