Determination of radiation vs convection in particle laden flow |
February 28, 2022, 11:38 |
greece
Rep Power: 9 |
i model particle laden flow in a vertical tube with constant wall temperature. This causes raise of the air stream temperature along the tube. 2 way-coupling is applied for particles injected from the one end of the tube to the other. I successfully simulated heat transfer to particles and air, including the effect of radiation with DO model. Now i need to quantify the effect of radiation on particles heating (wall to particles heat flux) versus that of convection (heat flux from air to particles or the opposite). Is there any way to make a comparison about the heat transfered to the particles through the 2 mechanisms? Thanks a lot! Panos |
convection, dpm, fluent, particle-laden flow, radiation |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 16:30 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 05:41 |
Combination of flow, radiation and particle tracking | Gerrit | OpenFOAM Running, Solving & CFD | 8 | January 29, 2016 04:08 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
