April 5, 2022, 08:04 |
channel flow
Christ Kenndy
Hello everybody,
I am developing a code for studying 'compressible convection ' in microchannels. So far ( last three months) I have managed to implement Grahams - modified - two-step Lax-Wendroff scheme. Now as a validation check ..I was trying to obtain the velocity - profiles for a fully developed flow down the channel..( including the developing profiles near the entrance..) Can I expect such profiles as a limiting case of my code for fully compressible channel flow..? If yes then should the density fluctuations be kept minimum..? ( and take isothermal case..?) Besides I am also faced with the problem of handling the entrance /exit for my code ..( should I use any extrapolation to update the grid-points at the inlet/outlet ) any comments/ suggestions are welcome .. Last edited by christkenddy; April 7, 2022 at 02:03. |
How to manage the pressure term in fixed mass flow rate based channel flow simulation | sjwon1991 | Main CFD Forum | 5 | July 10, 2017 07:21 |
rhoCentralFoam for channel flow | fportela | OpenFOAM Running, Solving & CFD | 22 | June 10, 2014 20:14 |
Question on the boundary condition for open channel flow, please help! | ripperjack | OpenFOAM Running, Solving & CFD | 0 | September 13, 2013 11:44 |
Gravitational water flow in closed channel. | Szymon85 | CFX | 7 | September 3, 2013 16:28 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
