Incompressible Fluid With Variation of Tempeture |
April 8, 2022, 07:50 |
Lucas Nascimento
Rep Power: 4 |
Dear All,
I have a issues about definition of a incompressible fluids, is it possible a variation with temperature? I has been reading this in a book, image below. Link image |
April 8, 2022, 08:31 |
Lucky
Rep Power: 66 |
Any material where density is at most an arbitrary state function of temperature is still incompressible, the partial derivative of density with respect to pressure is 0.
Incompressible means the substance cannot be compressed by mechanical forces (i.e. mechanical pressure). Its density and volume are allowed to change via other means. Incompressible and constant density do not mean the same thing. |
April 8, 2022, 09:43 |
#3 | |
Lucas Nascimento
Rep Power: 4 |
How include temperature in that definition? |
April 8, 2022, 10:31 |
Lucky
Rep Power: 66 |
Are we talking about fluids or continuum mechanics? In fluids, the Navier-Stokes equations contain only pressure, velocity, and density and don't explicitly contain temperature and other state variables. Hence, there's no need to differentiate between difference sources of compressibility and it is enough that the partial derivative with density is zero.
In continuum mechanics, everything is compressible and you have to keep track of the types of compressibility. If there's no volume change then it's trivial, nothing happened. If you want you can apply this same approach to fluid mechanics and just forget about incompessibility. |
April 8, 2022, 11:03 |
#5 | |
Lucas Nascimento
Rep Power: 4 |
April 8, 2022, 11:12 |
Lucky
Rep Power: 66 |
If rho depends only on temperature (i.e. it doesn't depend on pressure) then the material derivative of rho will always be zero and it will always satisfy the incompressible flow criteria.
April 8, 2022, 11:27 |
Lucas Nascimento
Rep Power: 4 |
So in this case, don't have coupling velocity-pressure and consequently don't have necessary to use SIMPLE, PRIME,etc. algorithms, corrects? The equation of state will be necessary to describe evolution of rho?
April 8, 2022, 11:31 |
Lucky
Rep Power: 66 |
You always have a pressure-velocity coupling problem because you don't have an independent equation for pressure.
Rho always has an equation of state unless this a degenerate case with a constant density. The difference is, if rho depends only on temperature then even the energy equation is weakly coupled and I can replace rho(T) with rho(x,y,z) and just prescribe the background density field and you wouldn't even know. |
April 8, 2022, 11:58 |
#9 | |
Lucas Nascimento
Rep Power: 4 |
So rho = cte and rho = rho(T) was the same problems in numerical perspective? This characterize a incompressivel flow? |
April 8, 2022, 12:17 |
#10 |
Lucky
Rep Power: 66 |
For fluids... yes. To give an example of what this looks like conceptually... a flow where rho is a function of temperature is like a mixture of a bunch of different but otherwise constant density fluids all mixing with one another.
It might be helpful to distinguish between compressibility of the medium and the divergence free velocity constraint (which we call an incompressible flow). |
April 8, 2022, 12:44 |
#11 | |
Lucas Nascimento
Rep Power: 4 |
April 8, 2022, 13:27 |
#12 |
Lucky
Rep Power: 66 |
Because you can have a very compressible medium, e.g. a gas, that flows in such a way that the divergence free velocity constraint is still satisfied.
April 8, 2022, 13:52 |
#13 |
Filippo Maria Denaro
Rep Power: 71 |
Just consider the density equation:
d rho/dt + v.Grad rho = - rho div v in case of a simple divergence-free assumption, you get D rho/Dt=0, that is the particle retains its density constant along the trajectory. But density can have time and space gradients. On the other hand if you assume rho constant in time and space then the velocity is divergence-free. The "incompressible flow" assumption is a mathematical model, it assumes that dp/rho=a^2 is such that the sound velocity is >> then the convective velocity. Note that for a velocity field going to zero the density equation says that d rho/dt = 0 but Grad rho could be not zero! That is a case for a stratification due to a temperature field. |
April 8, 2022, 14:35 |
#14 | |
Lucas Nascimento
Rep Power: 4 |
April 8, 2022, 14:49 |
#15 |
Rep Power: 71 |
dp=(dp/rho) d rho + (dp/dT) d T Ok, for example perfect gas model rho RT=p. So what? We are focusing on the assumptions for dp/drho. Incompressible flow model assumes that a small perturbation of the density (drho) produces an infinite variation of the pressure (dp). Only if you add also the omothermal assumption the density is modelled as constant in time and space. (Of course dp/drho at constant entropy is the correct sound velocity…) That is: - if you assume rho=rho0, the flow is incompressible and omothermal. In this case the pressure gradient in the momentum equation has no physical meaning but it is only a gradient field that ensures the divergence-free constraint. - if you assume only an incompressible flow model you can admit variation of density due to temperature (as it it assumed in buoyancy-driven flow, in combustion, etc). Pressure field still ensures the divergence-free constraint. |
April 11, 2022, 07:42 |
#16 | |
SAM
Rep Power: 14 |
Have a look at this paper. https://www.sciencedirect.com/scienc...17931014011478 |
April 11, 2022, 07:56 |
#17 | |
Lucas Nascimento
Rep Power: 4 |
April 11, 2022, 08:39 |
#18 |
Lucky
Rep Power: 66 |
It shouldn't be surprising... The state postulate gives that substance is fully defined by two independent intensive properties.
If you take pressure as a function of density and temperature: The variation of pressure with respect to temperature is the gas constant R. The variation of pressure with density is related to sound and compressibility That's it. There are no more derivatives. You are free to use other interpretations of course and consider density as a function of pressure and temperature and what-not but at the end of the day those variants have to be equivalent because they describe the same system. |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 18:19 |
Physics of an incompressible fluid | Jonas Holdeman | Main CFD Forum | 87 | April 22, 2019 10:40 |
Two phase incompressible immiscible fluid flow simulation | sinhavivekananda318 | OpenFOAM Running, Solving & CFD | 0 | March 22, 2019 01:12 |
Achieve Choking flow condition for incompressible fluid (Water) | kpsudhakar | STAR-CCM+ | 0 | April 17, 2013 02:44 |
Initial cinditions for incompressible fluid | Vladimir Fuka | Main CFD Forum | 3 | December 23, 2005 10:45 |
