April 27, 2022, 08:27 |
Inflation layers for multiphase flow
Brett
Rep Power: 13 |
Hi guys,
I've got a problem where a heat source is causing a fluid (refrigerant) to change phase. I've heard that using fine inflation layers in a situation like this is not advisable. Can anyone speak to inflation layers relating to multiphase flow and phase change? |
multiphase flow, phase change, y plus ranges |
Intuition for why flow follows convex surfaces | lopp | Main CFD Forum | 47 | February 1, 2022 13:14 |
[ANSYS Meshing] assistance with Inflation layers | cfxturbomode123 | ANSYS Meshing & Geometry | 3 | January 31, 2020 04:03 |
[ANSYS Meshing] Inflation Layers disappearing - airfoil | krekel13 | ANSYS Meshing & Geometry | 0 | January 24, 2015 13:55 |
[ANSYS Meshing] Inflation Layers around a 90 degree bend that is separated into multiple parts | Kaaji1359 | ANSYS Meshing & Geometry | 2 | August 18, 2013 18:57 |
Fluent diverges when using inflation layers | ziggo | FLUENT | 4 | August 9, 2013 12:11 |
