ICEM correspondence with Meshing
Old   June 7, 2022, 12:28
Default ICEM correspondence with Meshing
Nima
Nima Shah is on a distinguished road
I have recently done meshing in ICEM and saved an export with some names. Then the solution ws finished and so on.
Now I have opened "Fluent" to read the case and save it as a new case with slight changes.
The question is I am not sure which .msh file was selected when importing to Fluent.
I am going to delete some of the unused .msh files to gather some space for next solutions.
* I am going to use a Cluster to run my simulations and Fluent launcher.
Nima Shah is offline   Reply With Quote
Old   June 7, 2022, 17:36
Sebastian Engel
bluebase will become famous soon enough
I haven't used fluent in a very long time. So i don't recall if there is a journal-log somewhere which could tell you what has been done to the file.
But as a workaround, i figure, how about using the absolute cell count of your mesh. these are likely not identical with your set of meshes.
bluebase is offline   Reply With Quote
Old   June 7, 2022, 18:45
Nima
Thanks Sebastian. This might work but I guess there should be a more systematic approach.
Regards
.msh. case & data, export, fluent, icem, import mesh
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 09:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 10:09
ICEM meshing question gsbhatia89 ANSYS Meshing & Geometry 5 June 14, 2010 08:24
