Linearization of the source term of the diffusion equation |
October 27, 2022, 02:43 |
Zhejiang
Hi guys,
I want to solve a convection-diffusion equation with an absorption source term (Liner Driving Force model and Langmuir-Freundlich isothermals), but I don't know how to linearise this source term. Please see the following equations: where c is the variable, and others are constant. I wonder how to linearise this . Please give me some advice, and I really appreciate your time and patience. |
October 28, 2022, 05:22 |
One typically writes the source term as a linearization around a 0 state (i.e., previous iteration value) , but then the actual implementation depends from the specific method you are using (i.e., solving in delta form or not). See also https://www.cfd-online.com/Wiki/Sour..._linearization.
Hopefully, you can do by yourself, but the possibly problematic point I see here is that the derivative is not defined at c=0 (but the source term is). Honestly, I never dealed with such problem, but a possible way out is to simply saturate the derivative at a minimum value of c (but, again, this might depend from the implemetation). |
October 31, 2022, 09:27 |
Zhejiang
Thank you for your reply, I will read the web you mentioned.
absorptivity, diffusion equation, linearize, source terms |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
