Any open-source Python CFD library that can handle moving objects? |
November 17, 2022, 21:25 |
ON
I'm running design optimization problems in Python and require a CFD solver to compute objectives and their gradients. The problem involves an object (rigid body) going through both translational and rotational motions and a flow going over it.
It seems like OpenFOAM can simulate this type of problem using dynamic meshes...(http://www.wolfdynamics.com/training...s_2021_OF8.pdf) Is there any open-source Python CFD library that has the same capability? |
November 18, 2022, 03:52 |
Rep Power: 6 |
Python isn't normally used for writing CFD solvers because it would be much slower than when using, say, C++ or Fortran. But you could do the optimization bit in Python and only call OpenFOAM to execute the CFD solution, can't you?
November 18, 2022, 07:27 |
ON
Yes, but this would make the optimization slow because I can only treat the CFD solver as a black box... I want to use gradient-based optimization and possibly implement gradients (adjoints) myself.
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
