November 18, 2022, 19:17 |
ANSYS Flow Boiling Error
Austin Keck
I'm running a multiphase transient simulation of saturated liquid water flowing through a tube with constant heat flux from one side. I'm using ANSYS 2022 student edition. My required heat flux is 2*10^6 W/m^2 (2 MW/m^2) and the issue is after a very short period of flow time (<0.1 sec) the Courant number suddenly jumps to over 250 and I get a floating point exception error.
I have tried a number of troubleshooting tips - most of which are detailed on the "CFD Setup" slide of the slide deck linked below. The greatest improvement has come from reducing the heat flux by orders of magnitude, but I'm still getting flow times below 1 second before error. Even with heat fluxes as low as 2*10^3 or 2 kW/m^2 it stops at about 1.5 sec. https://drive.google.com/file/d/14ng...ew?usp=sharing Thank you in advance for your help! |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 07:11 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
