November 25, 2022, 02:45 |
Accumulation of gas at channel outlet
HR
Rep Power: 3 |
Hello everyone,
I am running a simulation of a narrow channel consisting of a fluid that is a mixture of gas and liquid. I am using the interFOAM solver for this. At the end of 1s of simulation I am observing a weird accumulation of gas at the outlet. I have attached the image of the issue and the mesh. I feel this accumulation is not physical and is causing disruption of the flow upstream. I have also attached the boundary conditions at the outlet for U, p_rgh and alpha.water here. Outlet U : type inletOutlet; inletValue uniform (0 0 0); p_rgh: type totalPressure; p0 uniform 0; alpha.water: type zeroGradient; I am trying to get a venting to atmosphere condition here. I also tried a zero gradient outlet condition but it too resulted in the same. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions | Vishnu_bharathi | CFX | 12 | November 21, 2017 06:56 |
Gas Turbine 1st stage - zero mass flow at the outlet | 8gcynamonu | CFX | 5 | March 27, 2017 03:07 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
pressure outlet (open channel flow) | Willem Brantegem | Main CFD Forum | 0 | April 3, 2007 09:39 |
