Two-fluid turbulence?
Old   August 9, 2000, 07:56
Default Two-fluid turbulence?
Sheng
Using two-phase simulation on two mixed fluid, one assumption is often used: the two fluid share the same turbulence, hence, only one selected turbulence model will be used.
However in the solution, it can be found that the two fluid are with different velocities (this will be used to calculate drag force, lift froce....). Then, why two different velocity liquid will share same turbulence? Are there any research efforts on that topic?
Thanks in advance! Sheng
Old   August 10, 2000, 11:30
Default Re: Two-fluid turbulence?
bellakhal ghazi
CHAHED J., MASBERNAT L., BELLAKHAL G.(1999) "K-Epsilon turbulence model for bubly flows" 2nd symposium on two phase modelling and experimentation, Pisa, Italy May 23-25, 1999.
Turbulence modeling of non-Newtonian fluid Katie CFX 3 February 10, 2018 17:51
SUGGESTION ABOUT SUBTOPICS Michail CFD-Wiki 0 October 14, 2005 07:02
Turbulence boundary values lego Main CFD Forum 0 October 24, 2002 13:47
Turbulence damping at fluid interface Eric Main CFD Forum 0 October 4, 2002 14:27
Large Eddy simulation Andreas Hauser Main CFD Forum 1 May 20, 2000 20:33
