The peak heat isn't located at the stagnation point of a 2D cylinder |
January 11, 2023, 09:27 |
Dengke Li
Rep Power: 3 |
Hello, everyone
Recently, I found that the heat flux results of a 2D laminar cylinder are mismatched with the fact. As we all know, for a hypersonic flow over a cylinder, the peak heat flux is located at the stagnation point. The true distribution of heat flux is like this But when I use some software or CFD codes to do the simulation, the result is that the peak heat flux is always a bit deviation to the stagnation point. The figure is attached. The grid is 2D and the height of the first layer is 1e-6m. I don't know why the CFD results are wrong, can anyone give me some advice? Many thanks!!! |
January 12, 2023, 04:15 |
Will Kernkamp
Rep Power: 12 |
The stagnation point will have the highest temperature if the wall has no heat flux. I suppose you gave the wall a fixed temperature. This means the wall is going to cool the flow near the stagnation point. At the stagnation point, there is very little fluid movement, so the cooling is more effective there relative to adjacent locations.
January 12, 2023, 04:37 |
#3 | |
Dengke Li
Rep Power: 3 |
Yes, I used an isothermal wall boundary for the cylinder wall. But in theories, the temperature gradient of the stagnation point is the highest and many experimental results prove that the stagnation point has a maximum heat flux. Here you can see a comparison of experimental and CFD results. experiment.JPG |
January 18, 2023, 07:40 |
Dengke Li
Rep Power: 3 |
That is not a link to the article!!! And my case is a pure fluid flow without the simulation of heat transfer in solid.
January 18, 2023, 09:46 |
What code did you use to get those results? Is it an immersed boundary code? If in house code, what method did you use?
Btw, you are right, higher heat flux should be at stagnation point for your fixed temperature bc. But the problem I see here is slightly different. The max heat flux seems shifted because of those oscillations that just seem to get worst at the stagnation point. Give more details and we will try to help |
January 18, 2023, 20:33 |
#7 | |
Dengke Li
Rep Power: 3 |
Thanks for your reply. The code I used is Hy2Foam, which is based on the OpenFoam framework. Now I think the reason for the unphysical result is that my mesh is not dense enough in the flow direction. But after refining the mesh, the peak heat is still located at a tiny distance from the stagnation point. |
January 19, 2023, 04:09 |
This almost certainly excludes postprocessing issues and also the code is not IB. Have you maybe done some of the tutorials of the code, to see if the problem is there as well?
January 19, 2023, 04:37 |
#9 | |
Dengke Li
Rep Power: 3 |
I have done some tutorials like a blunt cone. And the result is fine. This question just appears when I doing a 2D blunt body simulation. I also have done the simulation with some commercial software like fluent and CFD++. But it also needs a very dense grid to make the peak heat almost located at the stagnation point. From my side, this mismatch with the fact can almost avoid via a very dense grid. And it will cost much more time to achieve convergence. I still want to know why it needs a so dense grid when doing 2D blunt body simulations. |
January 19, 2023, 06:42 |
#10 |
Lucky
Rep Power: 66 |
More than the peak heat not being at the center, there is the greater issue that the heat flux is not smooth anywhere. I suspect there is some c-grid shenanigans that doesn't go away no matter how you refine the mesh because the same skewed cells are messing you up every time. It doesn't happen in the tutorial because, well, you followed the tutorial instead of doing things on your own. There is a lot more amuck than the peak heat not being in the center, don't bury them under the rug.
January 19, 2023, 07:08 |
#11 | |
Dengke Li
Rep Power: 3 |
Thank you for the advice. Yes, I know what you mean. But when I doing a sphere simulation, this mismatch will not take place. And the mesh is generated by myself. And the fluctuations always exist less or more because of the skewed cells. Could you tell me how to avoid these "c-grid shenanigans"? |
heat transfer laminar, hypersonic flow |
How to implement time-varying boundary conditions in an enclosed cylinder | Alejandro-FA | OpenFOAM Pre-Processing | 0 | May 14, 2020 06:29 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Conjugate Heat transfer- Heat generating cylinder & natural convection | sandymech | OpenFOAM Running, Solving & CFD | 6 | July 3, 2018 13:40 |
Convection heat transfer at stagnation point canonical problem | MachZero | Main CFD Forum | 9 | March 15, 2018 06:49 |
Volumetric Heat generation in cylinder with natural convection conjugate heat transfe | sandymech | OpenFOAM Running, Solving & CFD | 0 | August 9, 2017 18:36 |
