Simulation of a saturation of a porous medium on ANSYS CFX |
May 18, 2023, 06:51 |
Oluwagbemiga Fabunmi
Hello my fellow CFD experts.
I have a question to ask. How do you model saturation of a porous medium like a sponge. I am using a simple design. A block that acts as the inlet into the porous medium and another block as the porous medium itself. I applied water vapour at 25 degrees Celsius and inputted the volume porosity and permeability losses. However, I am not sure my results are correct. When I check results for mass flow rate in the porous medium section, the mass flow rises and falls and eventually flat lines; remaining the same for the entirety of the simulation. I figured it should drop to zero steadily as the porous medium becomes saturated with moisture. I am running a transient analysis for 6 months, using a day as the duration of each time step. Please I need your inputs. Thanks |
UDF for Sorption in Species Transport through Porous Medium | Kosch | Fluent UDF and Scheme Programming | 6 | October 21, 2020 17:46 |
2Phase flow simulation in Porous Media Ansys Fluent | Yaqub | FLUENT | 0 | June 22, 2017 03:46 |
Simulation of flow through a Pump as turbine by Ansys CFX | Aladinos05 | CFX | 6 | June 13, 2017 21:34 |
Convergence issues for a 3D Centrifugal pump simulation using ANSYS CFX | enr_venkat | CFX | 7 | August 31, 2016 18:58 |
Help with 2D simulation of carbon dioxide migration through a porous medium | bruno226 | FLUENT | 0 | March 31, 2014 06:42 |
