What is a Large Eddy Simulation without turbulent inflow? |
June 20, 2023, 12:17 |
ishan
Rep Power: 8 |
If inflow turbulence is not generated for a LES setup, will the LES solver act as an inviscid compressible flow solver ? Or is this behaviour code dependent ?
I think the behaviour will be like an inviscid compressible solver however, I would like to know why it would be or would not be. |
June 20, 2023, 13:27 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
No, not at all! Your LES solution will develop a physically correlated turbulence after some lenght from the inflow section. But that depends also on the initial condition, if perturbed or not. If not, you can wait a lot of time unit before to see turbulence developed in a certain region of the computational domain. Do not forget that a correct LES formulation is capable to solve the laminar, transitional and turbulent regime along a flat plate. Therefore, a laminar inflow is congruent, too. |
June 20, 2023, 13:33 |
ishan
Rep Power: 8 |
Thanks a lot.
large eddy simulations |
Eddy diffusivity and the simple gradient diffusion hypothesis | blyatman | Main CFD Forum | 4 | September 16, 2021 20:52 |
Pressure drop in pipe flow with Large Eddy Simulation | xerox | FLUENT | 1 | October 16, 2019 08:55 |
Large Eddy Simulation with too high Mach number | Roland R | CFX | 4 | November 25, 2010 16:43 |
Large Eddy Simulation,,,???? | tumble | Hardware | 3 | February 16, 2010 17:36 |
Large Eddy simulation | Andreas Hauser | Main CFD Forum | 1 | May 20, 2000 20:33 |
